Not entered a GB before and did not 'pre-register' so hope I can join in
I couldn't find a Fujimi F-4K or M at a good price but acquired this pre-owned but untouched Hasegawa at £18 which seemed like a good price\quality balance and a Grey\White USN Phantom was next choice anyway
Aiming to do a standard OOB build but realised there are no weapons included after I brought kit (bit naughty that as they feature on box art), got a Hasegawa weapons pack 3 on eBay for the Sidewinders and Sparrows and have 2 TERs and some Mk82 bombs on The way
I'll keep you posted on progress, looks like there will be some mainwheels and other oddments spare once I have worked out what parts I need, happy to pass these on in due course if anyone needs them
Edited by cjhm
OK, made a start, stuck some bits together
Was planning total OOB but think I will add some belts to the seats and do something about the bare panels in the cockpit instead of using the decals
Whilst this was going to be OOB, was seduced by Eduard etch set down at my friends shop, LSA Models in Hove.
Have made progress on cockpit, I used maskol mould pressed onto plastic-card softened with poly weld to make copy of left front hand panel to add to rear as etch set didn't have one. I know its not the same panel in real life but it looks good enough to me
Edited by cjhm
Cockpit nearly there
Kit pylons with Monogram TERs which will hold Monogram Mk82 bombs (Monogram parts kindly donated by Tadgh - most appreciated)
Great work so far, how do you like the Hasegawa kit? I have one to build as an Israeli Kurnass, I tohought I might do it over the summer if it's not too much of a hassle :)
Arnaud
Arnaud
Thanks for compliment, kit seems OK so far other than weak cockpit detail and if you have one already it should be a pretty straigtfoward build. If I had paid the £40+ some of these go for on eBay I would have been slightly disappointed as there was a bit of flash on some parts and fit on the main airframe which I was working on today is not as good as some modern kits (my kit is circa 1990 I think)
I am hoping the Academy 1/72 Phantom rumours produce a good family of F-4s ....
Edited by cjhm
Airframe coming together OK, seen here after light sanding, needs a few more parts and odd spot of filler
Some lead shot was superglued inside nose, not sure if it will be needed to keep nose wheel on the ground
Rear stabilators had to have the strengthening plates removed and panel lines restored
Edited by cjhm
Priming, filler and sanding (and repeat) in progress (apologies for poor pic, taken last week when there was a lack of natural light)
Primer is Simoniz white acrylic, good smooth stuff at < £5 for 400ml spray on eBay. I will leave this as is for white undersides etc
Started painting bombs and jetpipes
Edited by cjhm
White primer all sorted, masked and ready for the grey to be brush painted
Coming along, all brush painted after masking
Grey (Lifecolor LGG) then red (Citadel) and black (Lifecolor)
Citadel Chainmail and Boltgun Metal used for natural metal then toned\weathered with Badab black wash
Need to prepare for varnish before decals but just realised I should have added some etch to cockpit sides which I will check and sort first
Great work so far!!! I have some serious catching up to do with my Navy Ladies!!!!
Bexy
Help !
Carelessly left glue brush on top of a main wheel and ruined the detail then got it stuck to my finger trying to tidy it up and its a mess now
Anyone have a spare ? Its the thinner type of wheel\tyre (kit also has fatter -J type with seperate hubs, happy to pass these on if anyone needs them)
Thanks in advance
Edited by cjhm
  XV571 said:
I've got some spares. PM me your address and I'll pop a couple in the post.
Jonathan
PM sent, most appreciated, many thanks, Chris
3/8/11 - wheels arrived, thanks again to Jonathan
Edited by cjhm
Getting there slowly, been busy with non-modelling stuff unfortunatley
Managed to gloss (Vallejo spray can) and decals are in progress, few main ones and stencilling left to do
Latest setback (or challenge!) is that I dropped plane whilst getting ready to varnish which scuffed a red wing end (patched up before glossing) but also cracked joint between front\rear fuselage which I only noticed whilst decalling as a gap kept opening. Managed to apply some glue to rejoin things but this has left mark behind cockpit which should clean up once decals finished and protected with varnish. Lead shot nose weight also got dislodged and is rattling around.
Anyway, I'm not disheartened and am keen to get this one finished now
Edited by cjhm
How come youve got lead shot in the nose? Shouldnt be needed on an F-4, I never have in any scale. However, can you drill a small hole underneath and squirt some pva in then refill the hole?
  Quote
That is great to hear, youve done an amazing job with this one, even with the nightmares youve had :worthy: Did you paint your walkway markings or are they decals?
Bexy
Bexy
Thanks Bexy
Lead Shot - Thanks for suggestion, I will probably do that, perhaps from the UC bay, I only read about not needing the weight after I had added mine. And there was me thinking Hasegawa had forgotten to remind me to add some !
Walkways - Luckily they are the kit decals - a definite masking challenge if they were not included ....
I see you're having some challenges as well with your F-4 ....
All the best
Chris
Edited by cjhm
  cjhm said:
Thanks Bexy
Chris,
Youre welcome, its with a try..... I reckon the underside would be easier to hide / repair than the top or sides :thumbsup2:
  Quote
Im hoping I dont have a disaster with my decals Like I normally do, the wing looks easy, but that intake walkway looks a masking nightmare :yikes:
  Quote
All the best
Chris
Oh just a wee bit, though Im hoping another coat of white paint will hide most of the lumps & bumps, will be working on her again tonight so fingers crossed :pray:
Bexy
Nearly there, main thing needing attention is cockpit surround and canopies together with bringing together sub assemblies
After decals were finished everything was sealed with Vallejo satin spray can varnish, some MIG cold grey wash is being used to provide some subtle (I think) weathering
That's looking wicked. I must admit, I have the 1/48th kit with those markings, but was gonna finish it as an F-4N. But after seeing this little gem, I mat well have a re-think! :goodjob:
Right, its finished
It's not perfect but I'm pleased with it
Final stages with canopies were troublesome, I fogged one and scratched another but used 'Lakeland Quickshine' to recover reasonably well. Also used the quickshine for re-shining canopy surround matt black to match rest of finish
Thanks to all for compliments, support and help with parts
Some details in these pictures, please see gallery as well: linky (Post 14)
Edited by cjhm
