Peter Marshall Posted December 2, 2012 Posted December 2, 2012 Started this last week but i've nearly got the cockpit done, just needs a little more weathering. Peter 1
NickT Posted December 2, 2012 Posted December 2, 2012 Well, she's off to a great start. Can't wait to see how this turns out. Nick
Mike Posted December 8, 2012 Posted December 8, 2012 Nice work so far Peter - the Camera unit should actually be painted a "bone" colour - similar to Elfbein, rather than black/grey though. GWH also missed out the main spar that passes just in front of those MG ammo cans
tango98 Posted December 8, 2012 Posted December 8, 2012 Peter, Good job thus far but to add to what Mike posted, the frame supporting the camera was usually painted in the same colour as the camera. HTH Dave
Peter Marshall Posted December 8, 2012 Author Posted December 8, 2012 More done on the 189 - finished up the interior. I've not done anything with the camera as I like it black :-) Then starting with the glazing and the first MG's. Peter 1
mekon Posted December 9, 2012 Posted December 9, 2012 Lovely work, how are you finding the general fit of the parts?
Peter Marshall Posted December 9, 2012 Author Posted December 9, 2012 (edited) Today's work - yet more glazing. Got all the glazing on now Then all the masks on - they are good but not great. The vinyl is maybe a little too thick, and a couple needed a little trimming with a sharp scalpel. Finally a quick blast of RLM66 over the top to seal the masks, and to give the right back colour for the frames. The fit's good so far, but not perfect. The instructions could be better too. Peter Edited December 9, 2012 by Peter Marshall 1
HOUSTON Posted December 9, 2012 Posted December 9, 2012 .....and the classic beauty is off to a great start.. Oooh. I LOVE these birds... Nice clean methodical work Peter.
Parabat Posted December 10, 2012 Posted December 10, 2012 Wow, that pit looks great and the masks look comprehensive! Be good to watch this evolve.
erikmuntz Posted December 11, 2012 Posted December 11, 2012 You build at such a quality that I'm ashamed of whats on my bench right now. Looks like its going to be a great model of a unique aircraft! Erik
exdraken Posted December 11, 2012 Posted December 11, 2012 phuh! quite a masking job! Looks promising though!
Peter Marshall Posted December 15, 2012 Author Posted December 15, 2012 Got a bit more done today - first the disaster. As you are probably aware it's been a bit cold - this may have caused this: Any of the masks over a curve have come off. Never mind, out with the tamiya tape. Then made a start on the engines - still a fair bit to do Peter
Peter Marshall Posted December 22, 2012 Author Posted December 22, 2012 (edited) More work done on the 189 today. First I finished off the engines Then I managed to lose one of the parts for the landing gear, so queue an hour of slicing plastic card strip to make a replacement. Then made up the Landing gear Finally fitted the port wing / boom together - some Mr Surfacer on some of the joints, but nothing major Peter Edited December 22, 2012 by Peter Marshall
Peter Marshall Posted December 23, 2012 Author Posted December 23, 2012 (edited) Got a bit more done today, though the 189 has been a bit of a disaster area today, with some of the glazing falling off, the camera coming loose, but things have been patched together again. Finally got the booms sorted out and everything glued together Peter Edited December 23, 2012 by Peter Marshall
Peter Marshall Posted December 26, 2012 Author Posted December 26, 2012 (edited) resized pics Edited December 26, 2012 by Peter Marshall
Peter Marshall Posted December 26, 2012 Author Posted December 26, 2012 (edited) More done on the 189 - masked up the wheel wells Then sprayed with Alclad White Primer Pre-shading Sprayed the yellow theatre bands Then the RLM65 light blue Finally for today the RLM71 Peter Edited December 26, 2012 by Peter Marshall
Peter Marshall Posted December 27, 2012 Author Posted December 27, 2012 Today's work - about an hours masking Followed by the RLM 70, then unmasked Then finally a coat of Klear over the top Peter 1
Peter Marshall Posted December 28, 2012 Author Posted December 28, 2012 Decals on and another coat of Klear over the top Peter
tank152 Posted December 28, 2012 Posted December 28, 2012 (edited) Crikey had you been drinking before you put the balkenkreuz on the wing under sides! They're both well out. Edit, Just noticed the destructions show them to be positioned like that. I'm afraid they've got that wrong. They should be parallel to the fuselage and not to the wing leading edge. Edited December 28, 2012 by tank152
stringbag Posted December 28, 2012 Posted December 28, 2012 Crikey had you been drinking before you put the balkenkreuz on the wing under sides! They're both well out. Unfortunately, thats how they are shown on the kit instructions. However, this is a cracking build none the less. Chris. Chris
