AndyC Posted March 29, 2012 Posted March 29, 2012 (edited) I have decided to do a second entry in this build. I'm going for the 1/32 Revell Hunter F.6 but using Aeromaster's sheet for foreign Hunters Pt IV and I'm pretty sure it's going to be a Mk 56A for the Indian Air Force flying with the Hunter OCU The box shot The sprue shots And those Aeromaster decals Until later... Edited May 3, 2012 by AndyC
AndyC Posted April 1, 2012 Author Posted April 1, 2012 A quick update Sprayed the cockpit/wells/wheels etc NATO Black while on the sprue tonight Made a start on the cockpit too. It looks very good, the weak point being the seatbelts which I may try and improved with Tamiya tape ones. NATO Black with a dry-brush of Neutral Grey. Semi-Gloss Black on the isntrument faces and then a light dry-brush with Aluminium. Still to do the coloured switches yet but white on the dials been picked out and all the switches. Thanks for looking
canberraman Posted April 1, 2012 Posted April 1, 2012 Excellent work Andy, that cockpit looks fab. Can't wait to see this one finished! Mark
AndyC Posted April 1, 2012 Author Posted April 1, 2012 Excellent work Andy, that cockpit looks fab. Can't wait to see this one finished!Mark Thanks Mark - needs some new belts on the seat I think though - these are a bit anaemic
AndyC Posted April 4, 2012 Author Posted April 4, 2012 Just a quick update - got the cockpit finished and glued inside the nose. A little fiddly but looks OK Stuck about 30g of fishing weights in and will need more before I button the whole thing up. I also replaced the moulded on seat belts with Tamiya tape ones which will be painted Thanks for looking - I will be concentrating on my big 'Cat for the next week or so
AndyC Posted April 4, 2012 Author Posted April 4, 2012 Good job Andy, Would love one of these one day. Cheers! It's a fine kit Radleigh - I picked this up for £20 under the table at Cosford last year and got the decals off a BM'er
Iain Ogilvie Posted April 5, 2012 Posted April 5, 2012 Cockpit's looking great Andy - and you're right - 'tis a very good kit and has always been great value... Iain
AndyC Posted April 7, 2012 Author Posted April 7, 2012 A quick update! I've been working on the intake trunking - quite tricky to set up correctly because the instructions are a little vague. It's a better engineered way of doing it than the Academy one I've just done in the Hunter GB. I had previously primed and sprayed Alclad on the bits The finished item is glued into the cockpit/nose piece and than the rear fuselage sort of shrouds it. The other big bits have been glued - I only took a pic of the rear fuselage. I have yet to do the jet nozzle and rear piece. I finally laid out everything loosely to gauge the size and it's quite big! A bit of a sanding session and doing boring stuff like weapons and D/T's coming up. Also a balance test for the weight once I have glued it all up - the nose cone has been left off for that purpose Thanks for looking
AndyC Posted April 9, 2012 Author Posted April 9, 2012 (edited) I am still waiting for my stuff for the Tomcat, so I have pressed on with this instead. I managed to get a lot of sanding done and stuff glued together. The fit is very good actually and any filler is probably my fault in taking too little care in fitting - except for around the separate tail cone which was genuinely poor. Balance check for nose weight complete and the cone went on I primed the u/c and wheel wells and sprayed them Alclad Aluminium. You can see where I had 'issues' with the fit! Got the windscreen and canopy undercoated and the former fitted. I masked off the cockpit, tailpipe and inside the intakes. All the fiddly bits (small intakes, Sabrinas, jet fuel dump and small aerials) were attached and a final check done before priming with Halfords Priming complete - here she is with the three main paint colours - Indian Hunters wore the same DG/DSG/MSG as their RAF counterparts - all in Xtracrylix. Thanks for looking Edited April 9, 2012 by AndyC
SaintsPhil Posted April 10, 2012 Posted April 10, 2012 Nice work Andy, you've reminded me I really must resurect my Lysander.... Phil
AndyC Posted April 10, 2012 Author Posted April 10, 2012 Nice work Andy, you've reminded me I really must resurect my Lysander....Phil Cheers Phil - you should - I could get used to modelling in this scale (except for the room they take up when finished). I got the Dark Sea Grey on last night and aim to try and get the Dark Green on tonight. Hard-edged camo from looking at photographs I think. Medium Sea Grey undersides later this week.
AndyC Posted April 11, 2012 Author Posted April 11, 2012 Well, I'm cracking on with this one having done my Hunter GB entry... Got the Dark Sea Grey sprayed in rough patterns on Monday night and gave it a second lightened coat last night early evening. I decided to do a hard edge to the camouflage as the photographs of Hunters in their original 'garb' as delivered and up to the early 70's were in the DSG/DG/MSG scheme. So, lots of post-its and Tamiya tape later I sprayed the DG... I then went over it again with lightened DG (with a touch of white). I left it for an hour and then peeled off the masking to leave this... Pleased with that! Only couple of very small 'runs' that I have dealt with using a cocktail stick and will get lost under the weathering anyway. More masking tomorrow for the underside MSG. Thanks for looking
AndyC Posted April 14, 2012 Author Posted April 14, 2012 A very brief update - sprayed the MSG underside last night and took off the masking and it's OK! Klear on tonight and maybe some weathering in the next couple of days Thanks for looking
AndyC Posted April 30, 2012 Author Posted April 30, 2012 Hi all Just a quick update as I try and sprint to the finish - got her decalled and almost finished the stencils - (there are a LOT). I think she looks good in the Indian AF colours Hope fully she will be done and posted as complete by the end of the week. She needs some weathering and final coat applying before wheels and dangly bits Thanks for looking
Iain Ogilvie Posted April 30, 2012 Posted April 30, 2012 Looking very nice - always love the decalling stage as the model starts to come alive! Iain
AndyC Posted May 1, 2012 Author Posted May 1, 2012 Hi all Started weathering her tonight...she is going to represent a Hunter of the Hunter OCU which was involved in the Battle of Longewala (4-5 December 1971) in the Indo-Pakistan War. The OCU Hunters were instrumental in repulsing a major Pakistani armoured thrust and a comprehensive victory was achieved. They were worked hard armed with Matra/SNEB rockets on the outer pylons against Pakistani tanks pretty much in the open and without AAA fire support... I have used pastels and Tamiya Smoke to try and show a battle weary machine immediately in the aftermath - I'm not going to weather her any more than this - I don't think she would have been 'dirty'. I need to clear coat her shortly - she should probably be Gloss or Satin - I will see. Undercarriage next... Thanks for looking and all comments welcome
marc Posted May 27, 2012 Posted May 27, 2012 crikey she's a beast, I'm always impessed by the weathering you plane builders manage it adds so much realism. lovely build
bettymoo Posted September 18, 2013 Posted September 18, 2013 Wow, that looks fantastic, those are the exact same markings I used on my 1/72 revel hunter.
