I'm in with this one please
Will be out of the box apart from decals as the kit ones were never in the box and could get no reply from Pocketbond. Paul J came to the rescue with a set from a Hasegawa kit plus stars from a Revell sheet
Looking forward to this build.
Just one thing though, if you look at the box art it suggests that there are seven exhausts on each side!
How many HP was that Pony toting?
Trevor
Trevor
Well spotted, sorry to report the kit only has 6 each side ....
The original Academy kit DID have 7 exhausts, they re-tooled it to the current version - something to check before you buy 2nd hand!
Wez
Edited by Wez
Thats right. I recall my first Academy kit was this kit with the 7 stubs. Quite amused by this.
OK, started sticking some bits together for the cockpit, good detail compared to last 1/72 Mustang I did (Matchbox circa 1985 ...)
Looking good. I have one of these in the stash but will not be using the decals so if you get stuck you can have them.
Tony..
Looks good Bud she should build up well.
wellzy :headphones:
Cockpit painted, couple of coats of Lifecolor interior green followed by detail painting, bit of drybrushing on instrument panel then some Games Workshop\Citadel Gryphonia Sepia wash. Dots of Krystal Klear on instrument faces finished it off
Flash makes it appear very stark, colours are a lot warmer and subtler in the flesh
Edited by cjhm
Another one off to a great start.
Ian
- Co-host Britmodeller 2011 P-51 Mustang STGB -
Main assembly going well, wing to fuselage joint on port wing and underneath the wing where the intake joins need a bit of filler though
Got behind on this one but managed to do some stuff today
Primer of Lifecolor Interior Green has been brushed on to highlight any flaws in cleanup, lip of underside intake is main area needing further cleanup
Started to prep some other bits ready for paint, tyres and UC doors have prominent ejector pin holes so these have been filled with Mr White Putty. I have left doors as 1 piece until cleanup complete then I will seperate them
Decided on markings, will be Boomerang Jnr of 434th Fighter Squadron using the Hasegawa decals, plane is natural metal overall with OD anti glare panel and a red rudder
Started brush painting Citadel Mithril Silver, aided by some Windsor and Newton flow improver
Rudder finished in Citadel Blood Red and Anti Glare Panel in Lifecolor Olive Drab, Tamiya tape used to mask both areas
Decaling done
Mixture of Revell national insignia, Hasegawa for aircraft specific markings and a Microscale sheet for the odd stencil
