Just finished this one. Picked up for £18 from Antics at the Weston Super Mare show this year. I fancied this after my Mil-8 build which was a slog. The kit is built fairly out of the box; I did some research here and noted other commets that the canopy was wrong, the fairing around the exhaust was wrong etc.... In my search for reference material i found in a photo in a magazine and one on airliners.net of a SF with a canopy cover - ta da, so now i knew what i was going to do. The kit went together very well with only a tiny bit of filler around the topside of the wing/body join. I corrected the fairing around the exhaust (never noticed it until it was pointed out!). I cut out the foot rest below the cockpit and cut and lowered the elevators and trim tabs. The kit primed and a first for me i pre-shaded. The base colour of Sky was applied and then the DSG. The shading really stood out under the sky and it worked well on this kit. I wanted to fold the wings, so added some piping and busied it up a little. The wing lights were drilled out from the rear and i dropped colour into that hole (really quite effective). Decals applied (which were the kit version) and they were terrible. They felt almost plastic like?, but they did go down fine. Then the weathering, i was aware not to add too much and the exhaust staining seems to be at the bottom most exhaust, compared to the top which is relatively cleanish. Added the lights under the wing and the RBF tags. Canopy cover was added (tissue & water/PVA mix) and the tie downs added (stretched sprue), again using sprue for the spine antenna. Wheels ironed and painted red dots on the guns (airliners.net reference) that was it. Really quite please with this and it looks good. I was thinking about putting it on a base with a resessed floor, to give the impression its being lowered but we'll see....
comments or critisims please..............
Edited by speedy
I have to agree, that is lovely
As above, the wings folded correctly make a real difference as well, attention to detail, nice...
Hi again Speedy
"I cut out the foot rest below the cockpit"
This sounds really churlish and nit-picking about such a lovely model but I think the foot rest opened with the canopy. I really hope I'm wrong!
Steve
Hi again Speedy
Steve
Nice build.
Lovely looking model, and very well detailed, you must be pleased.
Dave
Hi again Speedy
Steve
Really - ah crap. I though it was opened when the undercariage was lowered. :tapedshut:
"Really - ah crap. I though it was opened when the undercariage was lowered."
You are quite correct. Please accept my apology,I should have checked photos on this very computer before opening my big mouth
Congratulations again on a great build.
Steve
Brilliant job Speedy, i like the canopy cover, really neat touch!
You are right, it needs a base to set it off with the canopy cover and the wings all folded with the rbf tags etc
Great looking Sea Fury! I love the canopy cover too. I've seen it done in 1/32 scale to hide the abomination that is the cockpit of the Hobbycraft Sea Fury. Can you explain what's involved in the tissue and PVA/water technique for reproducing it?
Kev
Kev
I read it on Aircraft Resource Center, there's a piece on there about intake covers. 2nd time ive tried it and it works. Tissue paper, PVA/water mix and paint away. When its dried trim to what you want..........
Guest snipersmudge
cracking model spedy, love the paint job you can really see the lines of rivets and the shading. will it be making an appearance on tuesday? :speak_cool:
So you shape and position the tissue paper first, and than paint on the PVA/water mix? I assumed you'd have to soak it in the mix and then apply it to the model. Now, to clarify one more thing: this tissue paper is not the same as ordinary household tissues? I'm assuming not...
Kev
Kev
Just the normal (cheapest) tissue you can get. The stuff you blow your nose with (Kleenex etc....). Cut the rough amount you want. Place it on the model. Paint brush the PVA/water mix. Let it dry (be patient - i normally let it dry over night). Trim with a sharp blade. Paint to what colour you want. If your covering a big gap perhaps put foil underneath, so the wet tissue doesn't fall in.....
Edited by speedy
That is very smart - a really nice job you've done there.
:thumbsup2:
Karl
BEAUTIFUL model Speedy!
The canopy cover looks perfect, i've never been able to replicate this technique convincingly.
Not a prophead, but i really like this one!
Al
Superb and (possibly ?) unique way to display a model.
Ian
