Peter Marshall Posted December 31, 2012 Share Posted December 31, 2012 (edited) Started this yesterdayFinished the cockpit now, and got the fuselage buttoned upPeter Edited January 13, 2013 by Peter Marshall Link to comment Share on other sites More sharing options...
ForestFan Posted December 31, 2012 Share Posted December 31, 2012 Excellent looking start, await more progress with interest! FF Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 1, 2013 Author Share Posted January 1, 2013 Some more done on the P-39 - first the radiator grilles in the wing roots Then the trickiest bit of this kit - the wing. With some fettling and gluing in sections it does fit, though you need to thin the trailing edges. Just some Mr Dissolved Putty and Mr Surfacer along the joints which is now curing. Peter Link to comment Share on other sites More sharing options...
Michaelvk Posted January 1, 2013 Share Posted January 1, 2013 That's some nice, tidy work.. Look forward to more.. ..might I add what an amazingly well lit workshop you have. Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 2, 2013 Author Share Posted January 2, 2013 Today's work on the Aircobra - first adding the rad shutters Then the canopy masks, and fitting the canopy. The canopy is tacked in place with GS Hypo Cement, then ran some gator glue around the edges to fill in the gaps and strengthen everything. Peter Link to comment Share on other sites More sharing options...
Silver Fox Posted January 2, 2013 Share Posted January 2, 2013 Looking good, fast work as well! Link to comment Share on other sites More sharing options...
Tim B Posted January 2, 2013 Share Posted January 2, 2013 Looking good Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 3, 2013 Author Share Posted January 3, 2013 Got a little bit done now, but mainly i'm waiting for my paints to arrive :-( Then i've done the insides of the doors Then glued the doors in place with some GS Hypo so I can remove them later, and sprayed the frames interiour green. Peter Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 4, 2013 Author Share Posted January 4, 2013 Paint arrived this morning, so onwards with the Aircobra - first mask up the wheel wells with Blu-tak Then a coat of primer, a little sanding, more primer and then sand back and rub down with a tac cloth Finally sprayed the light blue, gradually adding a little white. This is a gloss gunze paint, so from experience I know I have to let this cure completely before I start masking over the top Peter Link to comment Share on other sites More sharing options...
Greased Lightning Posted January 4, 2013 Share Posted January 4, 2013 Coming along nicely. Link to comment Share on other sites More sharing options...
Sid de Koning Posted January 4, 2013 Share Posted January 4, 2013 Nice work so far! Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 5, 2013 Author Share Posted January 5, 2013 Got some more done today - first sprayed the sand Then masked off the sand with blu-tak and sprayed the glossy brown - once again need to wait for this to cure completely Peter Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 5, 2013 Author Share Posted January 5, 2013 (edited) Unmasked the cammo Then masked off the ID bands ready for spraying Then finally sprayed the yellow and unmasked the bands. Peter Edited January 5, 2013 by Peter Marshall Link to comment Share on other sites More sharing options...
erikmuntz Posted January 5, 2013 Share Posted January 5, 2013 Looking great, Peter! Fantastic paint work on a less modeled subject and even a less modeled theatre! Can't wait to see the finished product! Erik Link to comment Share on other sites More sharing options...
Oddball Posted January 5, 2013 Share Posted January 5, 2013 Excellent progress Peter, I too am eager to see this one completed. Quick question if I may, I notice that you've used blue tape to mask the lines, and the wide Tamiya tape for the rest of the area. Is there a specific reason, different tape qualities perhaps, or it it just the way you do it? I just ask because only ever use the thin Tamiya tape for masking. Odd. Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 6, 2013 Author Share Posted January 6, 2013 To answer your question, the blue tape is Jammy Dog tape, it's just that I had some already cut, and being narrower it's easier to get around tight curves. Today's work - more masking, for the walkway strips Then sprayed them with Matt black and unmasked Finally a coat of Klear over everything Peter Link to comment Share on other sites More sharing options...
Tim B Posted January 8, 2013 Share Posted January 8, 2013 Looking good. Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 12, 2013 Author Share Posted January 12, 2013 (edited) Today's work on the P-39 - Decals. The decals aren't great on this kit - anything red or white seems to break up but i've got em slotted together Then I got the prop built up - drilled out the 37mm cannon barrel Peter Edited January 12, 2013 by Peter Marshall Link to comment Share on other sites More sharing options...
Tim B Posted January 12, 2013 Share Posted January 12, 2013 Super job. looking great! Link to comment Share on other sites More sharing options...
Peter Marshall Posted January 13, 2013 Author Share Posted January 13, 2013 Started the weathering today - first off a MIG Brown wash Then assembled and fitted the Undercarraige Fitted the prop, sprayed the exhaust staining, and started post shading Then started spraying dust / dirt on the surface then some heavily thinned Tamiya Buff Finally sprayed a matt varnish coat over the top Peter Link to comment Share on other sites More sharing options...
Tim B Posted January 13, 2013 Share Posted January 13, 2013 nice weathering mate Link to comment Share on other sites More sharing options...
