Heinkel He 111P-1 Exhausts (for Revell)
1:32 Aires Quickboost (QB32122)
Revell's big bomber was a huge hit when it arrived, but still leaves lots of scope for the super-detailer both inside and out. Quickboost's exhaust set takes all the hard work out of cleaning up and reaming out those twenty four exhaust stacks, which will be quite a task to even the most hardened modeller.
Instead the modeller simply has to cut each of the four exhaust pieces off the resin casting block, which has helpful protective end-caps to stop any damage to the delicate ends of the oval exhaust stacks. Casting is first-rate, even down to the weld marks at the base of each stack, and the hollow ends of the pipes go far enough in for the bottom to be out of sight due to the lack of light permeating the darkness.
Conclusion
A drop-in replacement to the kit parts for pocket-money prices that will save you a lot of repetitive and consequently very dull work, which should make them very popular. What's not to like?
Heartily recommended.
Review samples courtesy of
logo.jpg distributed in the UK by Hannants Ltd.
