I am already pretty far along with the build, but I just found this forum...
The cockpit is almost finished
The sidewalls are finished
All together
The fuselage is together
We have wings!!
The nose panels are on
The nose panels required a couple of shims (Tamiya tape) but the fit was very good and all in all, no problems.
Currently working on the canopy (moulded with a mould line down the center which has to be removed) but we are now up to date.
This build is really a blast and I recommend it to anyone who loves P-51's (or even if you don't!!
Thanks for looking in
Bud
Hi Bud,
Welcome to the forums! :)
For a first build back after all that time, it's looking absolutely fantastic!! :goodjob:
Beautiful painting on the innards, good fit, I can't wait to see this build come on!
Be sure to browse around the forums for other builds and modelling tips - you'll learn an awful lot here! ;)
Keep up the good work!
Tim
Hi Bud,
Tim
Thanks for the kind words Tim, this looks like a great forum...
Hi Bud,
That looks amazing!
And :welcome:
I have this one in my stash myself, by the way. Now I'm really looking foreward to get her started up!
Regards
Edited by KLP
Hello Bud, welcome aboard.:drink:
Fine looking Mustang so far, this kit is on my shopping list.
Will be following this with interest.
Edited by Kawacrossa
Thanks for the welcome and all the kind words. Currently waiting for stuff to arrive...soon as it does I can get back to work!! :lol:
Bud
welcome.
Went to an Airshow this weekend. had the chancer to stand next to seven Mustangs...A dream come true.
Lovely build and very clean.
Oliver
Edited by shark 64
welcome.
Oliver
You truly have had a dream come true, only way it gets any better is if you get 7 rides!!! :clap2: ...got any pics??
Thanks for the kind words, Oliver
One ride on the P51 for an hour is $ 900 dollars. They did a raffle going. I put my name in the hat and waiting for them to call me to tell me when I go up....Did I mention 3000 people were at the show that day and I bet many people put their name down as well. Dont worry Ill post photos when I go up.
Oliver
Looks like you spent 50 years planning this build Bud, because it looks seriously good! :thumbsup2:
Al
Haven't had much build time as we have been out of town but managed to get a little done on the canopy. The afore mentioned seam was treated to some careful knife work and then some careful sanding (starting with 1500 grit thru 12000 grit) and a dunk into some Future and we are rewarded with a nice clear canopy with no trace of the seam
with the masks applied and the inside taped, a little black is sprayed on
after the assy of a few parts
and we are almost ready for the paint shop
Thats about it for now...thanks for dropin in
Bud
Research (done by others) indicates that the North American Inglewood CA facility finished the wings of at least some Mustangs by puttying, priming and painting the surfaces. This caught my mind’s eye and I thought I would try to emulate this procedure. To accomplish this I filled, primed and wet sanded the wings several times until I achieved the texture I imagined was about right. Then I sprayed the entire plane with alclad II black base from a brand new bottle. It would not dry completely. I waited 3 ½ days and it still didn’t dry. I had read where the first time use had been fine but the second use, about a year later had resulted in this same result. My plan was to use it once (since it was brand new) and discard the rest. Very foolish on my part. It goes without saying that I will never use their black base again!!!!! Did I mention I am pi$$ed off to the max? To have an expensive kit that has hours and hours of work in it have this kind of thing happen as the last step is a real bummer. The Alclad folks need to respond to this obvious problem with one of their products (as my experience is certainly not the first) and make the appropriate changes to their quality control or lack thereof.
To try to salvage the build with at least a decent finish, I wet sanded the afore mentioned base coat as well as possible (I wear doctors synthetic gloves when holding the model for wet sanding and parts of the black base stuck to the gloves and pulled off in places) and sprayed the wings with Alclad’s “aluminum” last night to see if it would look alright and help the situation with the base. It has dried and looks reasonable but I didn’t build this P-51 to look “reasonable”. :rant::rant::rant:
The photos show where the base lifted. Not cool!!
Thanks for dropping in
Bud
  • 1 month later...
