Hello mates,
A long time ago in a galaxy far away, I had this idea of building the 1:72 Trumpeter Lightning F.2A kit. It looked great in the box, so it should be a nice quick little build, eh? Those of you who've been following my work-in-progress thread know that wasn't quite the case.
By the time I was done, I had used portions of the Trumpy kit, part of the old Matchbox kit (belly tank and refueling probe), an Aires resin cockpit and bang seat, the Eduard photoetch cockpit and exterior detail sets, Quickboost rear fuselage corrections and exhaust nozzles, Quickboost resin intake ring, Xtradecal markings for 92 Squadron, Xtradecal stencils, inspiration, perspiration, and a whole lot of very bad words. The WIP thread has all the gory details.
Thanks to the encouragement and expertise of my fellow Britmodellers, I think I've managed to make a reasonably nice model. Paint is mostly Alclad (aluminum, dark aluminum, magnesium, steel, dull aluminum, chrome, and white aluminum), Gunze acrylic (primarily H322 masquerading as Roundel Blue), and some Testors ModelMaster enamels. The final coat over the Alclad is their new Aqua Clear Gloss which I like quite a bit.
So here she is! Enjoy!
100_1832
100_1828_bw
100_1830
100_1829
100_1837
100_1826
100_1831
100_1846
100_1839
100_1840
100_1841
100_1844
100_1845
100_1863
100_1860
100_1858
100_1859
100_1855
100_1848
100_1861
By the way, my pilot has been severely reprimanded for not only leaving the nose wheel turned, but also the air brakes open and the flaps down! So belly up to the bar, mates! The first round is on him!   :)
Bill
Edited by Navy Bird
Photobucket Eradication
Wow ! That is a superb replica you have completed here of the unmistakable Lightning interceptor.
Clearly, all the hard work (and naughty words !) were well worth it.
Mike
Gorgeous, absolutely GORGEOUS!
That's one to take pride of place in the display cabinet.
Absolutely beautiful :wub: All your hard work has paid off in replicating English Electric's finest.
You've captured the shape and stance of the Lightning beautifully.
Definitely one to be proud of. :goodjob:
Bill you absolutely nailed it! This is the best model I have seen on here so far this year and the best Lightning I can remember seeing.
Trumpeter please note this is what a 1/72 scale Lightning should look like, not a stubby nosed, pork bellied freak on stilts! (rant over).
Bill,
This model is well worth the hard slog that has been the WIP thread. The attention to detail has paid off with a simply stunning rendition of a Lightning!
Mark.
That's a superb result - such accurate work in 1/72, and a lovely finish.
Ronnie
Lovely model all round! You seem to have captured the sit perfect! The shot head on slightly of to one side though.....wow!!! That's the one that does it for me! Daredn't build mine now!!!
That's a stunner, really nicely done.
Mike
Thanks, Mike. It was a fun project, I don't normally research as much as I did here, but in order to get a faithful replica it was required. It seemed like every time I found a fix for one problem, another popped up. Those were the times when my language relegated me to the naughty corner. I think the most common remark during the build was "you've got to be (expletive deleted) kidding me!"
I have quite a few Trumpeter kits in the stash, but this was the first one I've built. It did not leave me with a good taste about Trumpeter's design team!! I'm afraid to pull out the Sea Fury kit.
Bill
Just two words, very tasty..
Colin on the Africa Station
Thanks - I'm glad that it came out that way. I spent a lot of time comparing to drawings, figuring out what the correct wing anhedral should be, how long the main gear legs should be, where the wings should be mounted (Trumpy had them too far forward) etc. It was really important to me, because the Lightning is one of those aircraft where its stance is a "signature" - if you don't have it right, and Trumpeter most definitely did not get it right, it just looks "off." And it's far too important of an aircraft for that!
Bill
Yeah, I think that's my favorite shot too! I have a photo of a real Lightning in the very same pose, and it was one that I kept referring to during the build, to make sure that I captured that look. It's just an awesome angle!
And please, Nobby, if you have a Lightning in the stash, you owe it to humanity to build it! I am absolutely sure that you will do it justice! You will probably even scratchbuild the personal services disconnect that I left out of the cockpit.
Bill
Thanks Duncan!
I need to say that many of the Britmodellers helped me during this build, particularly Duncan, Iain, and Bill Clark, both on the forum and in PM. Even though I'm on the other side of the pond, you guys really helped with your expertise and advice! I can't thank you enough. I would have made some bone-headed decisions without you guys pointing me in the correct direction.
And yes, hopefully Trumpeter has been following the WIP thread!
Bill
PS. How do you get the replies to several messages all in one post? I did it one time, but I don't recall how. I don't think I manually edited the code, I think it just happened somehow.
